Topic: New Here 83 Thunderbird (Read 71846 times) previous topic - next topic
Must be, he said that the rear end from a Lincoln.
I think you wont be able to use the wheel caps or something along those lines.
Dang so I should get some different rotors, what car should I get some from?
My buddy who had car, says ranger rotors are on there, idk
Since they are Ranger rotors, you'll be fine. I forgot about those :mullet:. With the Lincoln rotors, there is the issue of the wheel centers not fitting. Sorry, deidn't mean to get you worried there.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
ok good, now I have to worry with nine inch under the it, should I measure from outside of rear rotors to get correct width.
You could do that, then just add the measurement from the wheel mounting surface to the outside rotor surface twice for your width. Good luck and have fun :D
86' T/C 4.6L DOHC
[/COLOR][/SIZE]
Rear end looks to be about 631/4.  I am measuring from outside of rotors to outsid rotors and then adding the space in to the mounting surface.
I ran the brake lines over from the block to the passenger side, I used the line from the parts car,  I hope I did ok on my double flaring, first time doing that.  I got new hoses also and clips to hold them to bracket.
XX
Reply #39
I mounted rack and the vacuum tee!!
X
Reply #40
Started the process of tucking wires, while waiting on some funds to get some other parts.  I plan on using some wire loom, I just laid it out today to get idea where it will run and make sure nothing will be in the way.
XXX
Reply #41
New outter tie rod ends!!
X
Reply #42
Nice project. Wish I was that handy.
85 TC stock auto
87 Sport 347, C4, 750 carb, LT, 3" exhaust
Reply #43
Thanks, you bird looks good!!
Reply #44
I put in a the filler neck to the gas tank from the parts car on Thursday.  The one that was on the car was shot out!!!
