Topic: Locar TV cable (Read 3111 times) previous topic - next topic
Locar TV cable
OK, first the back story. The plastic bushing at the throttle body broke and disappeared. Drove the Bird, not knowing about it, and lost 3rd and fourth. Thought this a perfect time to do my HO swap since the donor HO has an AOD attached. The Mustang with the HO and AOD was originally a standard and has not been driven much at all since automatic conversion. My HO swap is completed other than a few bugs to work out. Have not been able to get trans to shift at correct points. I turned it over to my tranny guy. He has found that he can not get enough adjustment out of the TV cable. May be something altered in the tranny, or could be this trans needs a different cable set up. Don't know because I don't know the origin of the trans. My solution is to get a cable from Locar and do away with the pivot. A Locar cable would most likely have an infinate adjustment. Problem is, I am finding multiple cables from Locar. Does anyone know the part# I should be looking for?
Locar TV cable
I bought one that said it was for a ford aod... I might still have the package....cause god knows I never throw anything away... lol
let me look
Locar TV cable
this is the one I bought..
it actually works for TB or carb with the parts and instructions they included... It doesn't say that, but I found a link on a stang forum that said to use this one.. I was actually a little scared when it got here and I saw the parts, because it doesn't look anything like the stock cable setup, but  it installed in about 15 min
http://www.summitracing.com/parts/LOK-KD2AODHT/
I believe, if you just have a TB on a carb base from an 85 or older... you need this part too
http://www.summitracing.com/parts/LOK-SRK-4000/
Locar TV cable
Quote from: daminc;396691
Thanks Jerry! I've got it ordered. Should get here by the end of the week. I'll let everyone know how it goes.
Locar TV cable
I used a Lokar kickdown on my 84 Cougar.  Worked great!  Especially paired up with a shift kit in the AOD
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
Locar TV cable
rannys
Does this kit remove all that junk linkage on these trannys ? Thanks Brian
Locar TV cable
what do you mean "remove all the junk"?....it's a replacement for the original cable, but it still has the springs and brackets and such much like the stock setup
Locar TV cable
Sorry I haven't  told everyone how it went. That part # was perfect. Shifts like a dream now. Only if it would idle.......
Locar TV cable
did you also look at the package and say..."I don't know about this....."
LOL
