Topic: need help, ignition pulley question (Read 829 times) previous topic - next topic
So i just put my head back on after 1.5 months and im having a hard time remembering which direction the white line on the pulley should be facing during top dead center. Does the white line on the ignition pulley points towards the cam pulley or the crank shaft pulley?
nvm, i figured it out
