Topic: for the life of me (Read 1265 times) previous topic - next topic
for the life of me
I can not figure out where this hose goes. I took my head off 1.5 months ago to ship down to boport for a stage 3 service and now that i have it back after this long time, i cant seem to remember/find where it goes.....
for the life of me
Im thinking oil breather but im not 100% sure
for the life of me
That, maybe, or fuel pressure reg.
Mike
for the life of me
Looking at a picture in the EVTM it looks like it may be a coolent hose to the oil cooler behind the oil filter.
for the life of me
It goes from the valve cover breather (located at the rear of the valve cover) to a metal line under the intercooler (passenger side of engine bay, right above spark plugs). Which runs up to the front of the turbo, where the rubber vam hose connects at.
The breather nipple points towards the firewall. The hose goes on there, then does the 90 degree turn to point towards the front of the car so that it can connect to the metal tube described above.
I could take pictures if that wasn't descriptive enough...... :D
...and there was light!
for the life of me
Oh good thank you very much for your help!
