Topic: Need Help Wipers and HVAC 20th anniversary cougar (Read 1475 times) previous topic - next topic
Quite often the windshield wipers will not seat into their off position, the switch will be off but it will make a buzzing noise and wipers will not go down. Have to play with the switch and run the wipers tons of times before they will seat. Also was wondering if the 20th anniversary cougar has a cabin air filter. i have very poor airflow coming out of the vents. any help would be greatly appreciated.
Check inside blower housing under the dash for mouse nest blocking airflow
Quote from: hwy73;396063
x2
Wipers,
check mounting bolts up front for the motor, then move on to the switch itself or the governer.
click on the photo bucket link below which will show you where all this stuff is at and get you started.
