Topic: wipers wont park (Read 1508 times) previous topic - next topic
wipers wont park
so my 88 tc's wipers dont like to park sometimes, and there is a humming squealing noise coming from under the dash. i assume this is the wiper governor box causing this?  eventually they will park.
 if so anyone have a good used one?
-pete
july/88 turbo coupe auto
wipers wont park
Quote from: ramair351;395601
Hi Pete,
I had a similar issue recently on my 83, and found that i had a bad ground on the wiper motor....some oxidation had built up on it. I cleaned it real well and no more problem.  Sometimes the best solutions are the easiest ones.
wipers wont park
thanks for the cool cats link Mike. i think too the governors my problem. unfortunately sounds like its not fun to change.
-pete
wipers wont park
Mines gone out a couple of times and I just keep changing the whole motor. 3 bolts and a clip and you're done. The only problem if you use used ones it might be bad to. I got lucky with the one I just put in this summer. Of course I have quite a few to choose from.
wipers wont park
once upon a time i chased this issue,
mult-switch did not fix
replacement known good wiper governer did not fix
gave up..............then found all the bolts were loose holding the motor.
apparently if the bolts are not tight, the motor and linkages will sorta bind up and probably not let it sense the correct radial orientation its in and never activate the park signal.
