Topic: Computer (Read 3012 times) previous topic - next topic
Computer
I was wondering if someone can tell me where my computer is located on my 1986 Cougar with a 302 engine? I bought a JET performance chip and I want to see if it does anything.
                                                            Thanks!
Computer
Behind the right side kick panel.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Computer
Quote from: 86cougar;395500
                                                            Thanks!
Passenger side kick panel, behind the plastic.
And the chip won't do jack shiznit. Throw it in the trash, or get a refund.
Seriously.
It's the parts you can't see that will make the real power...HO cam, E7 or GT40 heads, bigger exhaust, injectors, etc etc...
Chips are really best for seriously modded engines that there are no factory tunes for...such as a blown and nitrous fed engine...even then, to get the most out of it, it needs tuned on a dyno by a trained technician.
Hope you didn't spend a lot for this chip...
Computer
Problem is, I have to deal with emissions here. If I didn't, I'd just drop in another engine.
Computer
Emissions or not, the chip is only going to affect your wallet.
As long as you have good cats, a properly functioning smog pump, and all the parts between it and the Thermactor and EGR are working, heads, and HO cam will get past emissions. After all, they were factory equipment on '87 up Stangs and Mark VII 5.0 cars....
Let me reiterate, the chip will not help you with emissions, power gain, freedom of speech, gun control, or penile enlargement. It WILL lighten your wallet though. If those chips did anything, we'd all have 'em in our sigs as a mod lol.
Computer
Quote from: ThunderbirdSport302;395510
...or penile enlargement.
shiznit, there goes my last ray of hope...
Computer
Quote from: Thunder Chicken;395513
Yeh...you 'n me both..:eek:
Computer
now I want some pringles.... thanks
Computer
did someone say ChiPs?
Computer
I could have bought cases of pringles for what I paid for the Jet chip. Oh well, as long as I have food in the fridge and a roof over my head......I'm good.  Thanks!
Computer
Quote from: MY83T;395537
Putting those in your car would not be a good modification either.
Computer
Might be room in the trunk....
Computer
Generally speaking old school chips like a Jet, just jack up the timing.  Which will require premium fuel, on a 155 HP 5.0  hmmm.  If u want more timing just up the base timing from 10 to 12-13.  It will do the same thing for free.
Good luck,
Travis
Computer
So, if I advance the timing a little (I usually do) AND put my might Jet chip in.....who knows, I might get........ oh-oh, that's 155 hp new, my car is 26 years old. So, back to the equation.... about 120 hp, advance the timing and hook up the mighty Jet chip and...... Jeez, sure is a good thing I like my car. I better get back to work.  Thanks!
Computer
In some cases a chip really can help a basically stock car.  With the basically smooth cam the Ford installed in our cars with the 5.0....its going to be rough to gets lots of power, chip aside.  That is why the HO swap is so popular!
Travis
