Topic: Headlight Lense Options (Read 6796 times) previous topic - next topic
Hey Fellas, Got an 87 Former Turbo Coupe with somewhat opaque lenses.  Did a little research but was looking for the simplest factory-looking lens upgrade choices.  Didn't want to mess with the wiring since the interior is pretty factory fresh.  Pics would be great to aid in the decision.  Thx
Thanks for the links. I was thinking something beyond the factory replacements.  The ones I have are factory replacements and they only lasted a few years under semi-protected conditions.  Thought you guys might have come across some OEM looking clear lense replacements/retro fits.
Only '87/'88 Thunderbird headlights fit Thunderbirds. Nothing else swaps over.
Quote from: jdouglas87;395361
I was thinking something beyond the factory replacements....... clear lense replacements/retro fits.
:D
...and there was light!
Make me a pair of those.
Quote from: vinnietbird;395377
I can definitely make another set.
PM me the details, and the $$ amount.
Quote from: vinnietbird;395427
Same here. How much trouble would it be to make a set for a Mountaineer/Explorer, as well?
Will do.
Quote from: ThunderbirdSport302;395428
Sure thing. For the Explorer, as long as it has clear lenses it is very doable. Even if it doesn't have clear lenses from factory I would bet there is aftermarket lights available with clear lenses.
Quote from: T-BirdX3;395429
http://www.foxtbirdcougarforums.com/attachment.php?attachmentid=29834&d=1341535540
Like this?
Not like that, no.  It can be done with a lot of elbow grease and determination, along with sand paper and rubbing compound.  OR, you could start with something like this:  http://www.andysautosport.com/ford/1995_2001_explorer/lights/headlights/spec_d/spcd00010099.html which is perfectly retrofit ready.
No, those will cause massive amounts of glare.
Quote from: TheFoeYouKnow;395438
Something like this works very well, notice how the lense is clear with no diffusers/flutes in it.
