Topic: 3g wire delete help (Read 4268 times) previous topic - next topic
3g wire delete help
Im in the middle of a 3g upgrade amongst other things on my 88 5.0 cat.  I was able to remove entire harness for front lighting, horn and charging system by unplugging from drivers side 2 major harnesses, a 2 wire harness and the lug from the solenoid.  I removed all the electrical tape, flexloom and tracked down what goes to the alternator.
I purchased a premade d shape connector for my 3g that has the yellow/white wire hooking onto the lug of the alternator with a ring connector, the green/ red wire going to cars old green/red wire and the white/black wire looping around and connected to the single male spade inside the alternator.  What this leaves is me needing a heavy gauge and fuse coming from the solenoid.
What i have noticed is the yellow/white wire( voltage sensing wire) in the carsi harness is obsolete due to the new d shape connector loops it over to the lug where the heavy gauge battery cable and fuse will be hooking up from the solenoid. This is also where the cars yellow/white wire and fusible link join up with more wires at the same solenoid lug.
My question is, by deleting the cars yellow/white wire and fusible link from the
lug is this going to work the way its supposed to?  The way I see it, the voltage sensing wirw on the alternator will be picking up voltage at the power twrminal at the alternator?
3g wire delete help
The alt only needs an exciter voltage ONE WIRE. This comes from the alt light. If a gauge it can be a battery lead switched.
3g wire delete help
What you have done will work fine. It's OK to delete the stock Y/W wire.
In the stock setup they sense the voltage closer to the load. The regulator would then raise the voltage enough to compensate for any voltage loss between the alternator output and the load.
Nobody ever worries about that with the 3G upgrade.
3g wire delete help
I eliminated the fuse links altogether and installed an output lead I had pulled off a used Escape motor we were throwing out. It has a 175A fuse molded into the line and I switched the field power to an inline mini fuse holder at the solenoid where the fuse link had been.  I probably don't have a proper appreciation for fuse links, but I like fuses.  They change out fast and I've got lots of spares.  Lots.
3g wire delete help
I was trying to trace all the wires in the first part of the harness and fusible links to find out which ones are redundant.  I snipped and capped the orange/black wire close to the larger gauge yellow wires and fusible links.
I am assuming that 1 of these plugs goes to the cars computer (ECM) and the other goes to the dashboard and fusebox? Is there anything else from this area that can be deleted or should I consider this area at the solenoid and under the battery tray batch of wires ready to be bundled up?
3g wire delete help
I do like the idea of using an underhood fuse/relay box from another Ford product. These cars really do not have any extra room next to the battery to run the power leg from.  I thought about running a power cable all the way to passenger fender/frame rail and adding one.  This way I could have a MEGA fuse for my alternator to run off of and have a place to store my fuses and relays for my headlamp harness/relay upgrade.
I wonder if I could run my power for my headlamp relay harness from the orange/black hot wire that used to run to the alternator??  It is getting power from a lug off the solenoid and I could fuse my highbeams and low beams from this if I decide not to use the underhood fusebox.
3g wire delete help
If you're going to run your headlamp relays from anyplace, it should be from the battery.  Since I like terminated cables, this is how I do mine (pic is an example, my work on an expedition) so that I have good attachment points later.
X
X
3g wire delete help
Quote from: TheFoeYouKnow;394734
X
X
Good solid connections!
3g wire delete help
I hate to tell you that those connectors are GARBAGE. They loosen up and i never use them. Havent for many many years. Just me could be wrong again
3g wire delete help
They're solder filled copper terminals and without a torch, they will never come off that cable.  Neither will the nuts in the terminal base.  The lead universal terminals will last YEARS longer that the new stamped steel ones I've started seeing, and when they do wear out, you unbolt them and bolt the cables to a new one.  I've been doing it that way for at least 8 years, and never have problems with it. Not one single time.  When I learned this method, the tech who taught it to me was at least 3 times my age.  I usually also use waxed heatshrink tubing, but for this one I didn't have any handy.  What you can't see in the picture is that these lead terminals nave nyloc nuts in the base for the 2 bolts. I only discovered those terminals year before last, but even before that I haven't had trouble with them.  I experimented for a while with putting the bolts through the other way so they were like studs, but I didn't like that way it looked.
This is my Kung Fu, and it is strong.
3g wire delete help
Those look like a nice connection. I also haven't had any trouble out of that style setup. The only thing better that I have found are the same lead type but they have four bolts to hold them together. Now they make some that have a steel top plate but they also make them with a thick lead top plate those are the ones that I like the most. I due believe they call them HD or mil-spec something like that. I also like the soldering of the copper lugs nice neat clean  and yes it takes a torch. I buy plain cooper lugs and use strips of solder I slide in the lug with the wire. Give them a nice pinch with the vice and a torx bit to press in just the center, then heat with torch and when cool cover with heat shrink.
Stuckman
3g wire delete help
I lock them lightly in vice grips so they stand in place hands free, then I heat the open end of the terminal (usually with my mapp gas torch) and feed it solder til it's half full, then I quickly move it to the vehicle (I've stripped and fluxed the cable end beforehand) and insert the cable end into the terminal while the solder is still molten.  I hold the two together for about 30 seconds and then I slide the heatshrink tubing up the cable (I put the tubing on before the terminal) and shrink it down with a butane torch.  I put the bolt through the plate and the terminal end, and tighten down both bolts (not every one of these I do has multiple cables per terminal like the pic shows).  Sometimes I get a battery terminal that comes with regular nuts in its base, but I just get a couple nylocs from parts and swap them out.  No crimping needed.
3g wire delete help
THEY SUCK CASE CLOSED. Just me most likely wrong again.
I use crimp ends that you fill with solder.
First the cable ends you posted do not make a good connection. By bolting them with a 1/4 20 i do not consider that a good connection. Second they are one size fits all. Top post battery's have 2 different diameter posts. That means the connectors are different for pos & neg. When you use those connectors you are installing a connection with a joint at the worst possible place. Below is a good set of connectors that you first crimp they are wire sized for the correct application and they are clearly marked POS & NEG. After crimping with the recommended tool i flow solder in the cavity then shrink tubing for the approperate color. Red for POS And black for NEG. The connectors below are the only way to do it. This will give you a resistance free connection and they dont look like a cheese quick repair. Note below the two connectors are clearly designed for pos and neg application along with the proper wire size for a perfect connection. Note they are clearly marked Pos and neg.  Just me could be wrong again
3g wire delete help
With the wire delete for the 3g upgrade, how far has everyone gone with this?  I dont like the idea of having a couple of capped off hot wires sitting in my engine bay, especially under my battery tray.
The bundle that the orange and black wire goes to, there are a few larger gauge yellow wires and some fusible links that all connect to the main harness.  Is this for the cars computer?
3g wire delete help
Those are nice terminals, where do you get them, how big are the cavities, and how in Gods name are you going to cleanly install 2 cables (like the car in my pics) into one and have it look neat?  Don't get me wrong, they are nice, and I might use them on the right project, but these are not the solution for every vehicle.  My repair is neat, problem free in my extensive experience with it, safe, and strong.  These terminals in your pic, Tom, are well suited to vehicles with a single cable to each terminal. but I think it would look like a square peg/round hole repair with 2 cables coming out of it.  You're welcome to show me a pic and prove me wrong, but in my imagination, it seems like it would look crammed.
