Topic: cooling problems (Read 3226 times) previous topic - next topic
cooling problems
You can use a mach 1 "chin spoiler" from the newer mustangs. I have also seen people make them out of garge door sealer rubber strips.
cooling problems
idk what its suppose to look like can someone take a picture of one if they dont mind. like one on there car
cooling problems
Its just a small rubber strip pointed forwards that bolts to your lower radiator support to diflect air from under the bumper into the radiator.
cooling problems
alright ill try to figure something out to work.
cooling problems
PM vinnietbird.  He has the Mach 1 chin spoiler on his 88 Sport.
Darren
cooling problems
Hi!!  I just saw a comment on air dams and I started wondering...  I have a 3.8 which has a coolant temp needle on an '88 running upscale when the weather is 80 F or above.  This bird has an initial 15 year history for which the needle never much exceeded 1/4 of the way across the scale and rigidly stayed there regardless of engine activity.  The fact that the needle has any motion when the car is stopped in gear or going under load makes me believe something is wrong--which it has been doing now for years.  2 years ago, I went out on an interstate on a hot day and the needle climbed right up to the red line.  I made it home but have stayed away from those cirspoogestances since.  All components seemingly check out as operable and I am left with the thought that the radiator is going out--but even there, the radiator appears to have a decent temperature change and has always been clean.  Now the question:  Back some 7 years ago we put new springs on the front end--one was broke at the end of a coil and you wouldn't have known it, by the way.  Unfortunately, I think I was sold longer springs (say springs meant for a 5.0?) which raised the front end of the car maybe 2 inches.  Could this impact air flow design to affect cooling anyone???  I can't imagine it would make any difference.
cooling problems
Change the sending unit if you have not done that.
Darren
cooling problems
Will check that out...thanks.
