Topic: Shuddering engine...UPDATE July,1 (Read 19524 times) previous topic - next topic
Reply #105
If you pass the ballance test, I would assume it to be an o2 issue. Pull them out and try cleaing them, and if that doesn't work, replace the sensor.
You can temporary bypass the o2's by un plugging them. This will cause the computer to go into a type of fail safe mode, and it will run the car bassed on standard tables and turn off the adaptive fuel strategy that is used to account for the way different engines run and wear on the engine. If the miss goes away with o2's unpluged, its probably just a bad o2 reading.
Reply #106
Ahh, your quick.
Reply #107
I'll try that test as well.....after I figure out how. I'll check out the SBFtech info.  !!!!!!
Reply #108
Would bad O2 sensor (s) cause the car to have a backfire? The Sport has done it 4 random times, at lower rpms, like accelerating slowly from a stop.
Reply #109
Alrighty....status update.....
The balance test, if I did it right, shows an 8, which is cylinder 8. Plugged injector? Not sure.
On the "wiggle test"...I got a code 95....fuel pump secondary fuel circuit fault....no idea what that means.
Before the balance test, it went through codes, and gave me 4 of them....
94
44
33
21
That's where we are right now with the Sport's health issues. Now, what do we do?
Reply #110
Quote from: softtouch;392775
The balance test takes awhile so you will have plenty of time, or you can operate the throttle under the hood. Or you can place your meter where you can see it through the windshield.
The test will turn off the engine when it is done.
After the cylinder balance test is done the engine will return to idle and the computer will display the code (9 is pass, any number 1-8 indicates a bad cylinder). The engine will not shut off. It will continue to run until it is turned off via the ignition, as normal.
Reply #111
Yeah, I got that. I got an "8" on the test. SOMETHING going on at the number 8 cylinder. I'll check the injector (looking for a replacement now) check the plug again, and hopefully it's not a valve. I doubt a valve is the problem.
Ready for any ideas at all............
Reply #112
Quote from: vinnietbird;392904
94
44
33
21
On the KOEO test the code 95 is the wire you didn't run for the fuel pump monitor when you did the MAF swap (I know because I didn't either and that's the code mine throws during a KOEO test).
If it showed a code of 8 then yes you need to check cylinder 8 to see if the injector, plug, or plug wire is bad.
94 and 44 relate to the Thermactor system. If you don't have it ignore the code (my Thermactor system is gone and those are the only two codes my car throws during a KOER test).
21 means the ECT sensor is out of range. Was the car fully warmed up when you ran the test? If not that's why it threw the code. If the car was cold ignore it.
33 relates to the EGR not opening. Since you don;t have it ignore it.
If I were you I would start looking a cylinder #8 for a problem.
Reply #113
Quote from: vinnietbird;392909
Try switching the #7 and #8 plug wires (keep the same firing order just switch the wires between the two not the firing order)  and see if the problem moves to #7. If so you have a bad plug wire ;).
Reply #114
I just put brand new wires on yesterday with no change to the problem. I'll pull the injector Sometime this weekend. Gotta work 12's the next two days. .
Reply #115
Just pulled the number 8 plug. Nothing eventful there to see.
Reply #116
Theoretically, could a malfunctioning, not fully operational, mildly bad injector cause the car to pop from the exhaust?
Reply #117
Compression test in #8 while that plug is out,
Reply #118
I would think that the popping would be more valve train in nature than an injector...not what you wanted to hear i'm sure :(
Reply #119
Bad valve maybe? Hope not.
