Topic: wtb hood release cable 1988 (Read 919 times) previous topic - next topic
1988 TC hood cable needed. my bracket broke where it attaches to the kick panel by the ebrake
-pete
july/88 turbo coupe auto
I need one also....so after Pete gets his, someone post or PM me also.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
Just a heads up.  A cable from an SN 95 will work and the release lever bolts right in.  Looks factory.  Hope this helps if you can't find an original.
I am parting out an 88 XR7. I have one for you. You need everything? The brackets, cable, etc?
1988 T-Bird. 347 Stroker, Ported & polished Pro Comp heads, C-4 with 2800 RPM Stall Converter and the rear end isn't done yet.....:flame:
the bracket is molded to the cable handle under the dash. how much? shipped to 49442?
-pete
