Topic: GT40P heads (Read 3434 times) previous topic - next topic
GT40P heads
I'm selling the GT40P heads that I was running on my Thunderbird. The heads have about 6,000 miles on them. I removed the heads and replaced them with Edelbrock Performers. There is nothing wrong with them I just replaced them because I wanted to go faster ;).They have exhaust valves that have the same height for the valve locks as the intake valve so they don't have exhaust valve rotators. They are the stock GT40P exhaust valve size. The springs install at the same height on both valves so they don't need offset keepers or retainers if you use aftermarket springs. I'm asking $300 if you pick them up but it would probably be closer to $400 if you want them shipped as they are heavy. I do accept PayPal.
GT40P heads
More pictures.
GT40P heads
I may be interested, will have to see how much play money I have this month.  I would need them shipped though, Chicago is an 11 hr drive and I would spend more on gas then shipping I think
GT40P heads
I may have a local sale pending. If not they'll still be for sale :).
GT40P heads
So far still for sale :).
GT40P heads
You know you want these instead of your py E6 heads ;).
GT40P heads
Quote from: thunderjet302;391702
I do..But according to your last post about GT-40P heads..Is that it wont work with T_Birds stock Block???
GT40P heads
I bet you a dollar they would.
GT40P heads
I'll see your 3 bucks, raise ya 5, and call. Well, anyway, they'll work with a stock SO cam, and even an HO, but with pistons w/o the valve reliefs, I'd be wary of a cam with any higher lift than an HO cam.
GT40P heads
When I checked with my engine builder he said no way. He said with the stock HO cam the intake valve in the GT40P heads would smack the pistons. I think Zonda tried with the GT40s, stock block, and a HO cam and he had to fly cut the pistons for clearance.
You could clay your set up and see if they fit with your combo.
GT40P heads
Quote from: thunderjet302;391796
What is the difference between SO Block..And HO block..Is it only the pistons?? and nothing else?
FYI i checked with some big cats in the L.A racing scene here in CA..And my guy said they would work..Even with a certain ford racing cam..With no issues..
GT40P heads
Quote from: 88turbo;391803
I have SO block HO Cam and GT40P heads, no issues.
That makes me feel better...Was it a night in day difference in power in torque? Also did you leave your roller rockers stock..?
GT40P heads
Quote from: INFAMOUSAPA;391901
I'm using the factory stamped rockers and power difference is amazing....
