Topic: garage door (Read 1807 times) previous topic - next topic
garage door
away for holiday,son called{garage door springs and rollers snap,fell on my 86 xr7 that never washiznit}got luckey garage door trashed and passenger fender dented, so need  clean
fender i will paint if need- are regular cougar and xr7 cougar fenders interchangeable.
garage door
They should interchange, unless the XR7 fenders have different trim or badges that i don't know of.
garage door
The only difference would be corning lights.  Make sure the donor and your car either both have them, or both do not have them.  Although you can cut holes for them if your car has them and the donor does not.
garage door
Quote from: salrock54;391000
That's a scary thing. What kind of spring was it and what do you think the cause was?  Best of luck fixing up your car.  Is it so bad you can't pull the dent and repair?
tbirdregistry.com
26480
27373
garage door
The xr7 trim was diffirent, and wider for certain years, not sure if it would be a problem swapping them or not though.
Any 83-86 fender should work. My 86 gs had small thin trim, the 86 ls had slightly thicker, and I believe the 86xr7 was a diffferent style, not completely sure though.
garage door
the slim trim was for the body line, the back moldings and front were thicker. The Xr-7 did have the wider moulding all the way around but the smooth kind not the ridged version like the Thunderbird had in 83/84.
X
garage door
I had the tip of a garage door spring break off and I was lucky I wasn't killed. That thing ricocheted all the way around the garage before it stopped.
If you have the old style, before they put the safety cable in them, you should replace them.
