Topic: Marchal 750/759 fog lamps & covers NOS (Read 2208 times) previous topic - next topic
That is a true statement, Demon
Yea they came with the slimmer hella fog lights but was just wondering if someone has ever Swapped them to the Marshals
I've often wondered if the slimmer Marchals would bolt up to the TC brackets. Escort GT, Daytona, etc. Looks like the harness is different though...
I think I have a set of those slimmer ones in the garage somewhere.
Quote from: Ramos617;448634
I tried it before and couldn't get them to work w/o a lot of modification.. If I recall the Marshals were too wide( top to bottom) ... I believe someone on NATO has done the swap though.
 S O L D
