Topic: Fuse Links (Read 3480 times) previous topic - next topic
Fuse Links
This  DODGE was almost HISTORY. The alternator shorted out and burned the wiring harness all the way back to the DASH. I made a new harness.  This car was 100% restored by us but the owner did the wiring. This is a prime example of fusing and fuse links. When building a car always remember to include FUSE LINKS on the alt and main junction feeds. The rule of thumb is 2 wire sizes lower than the wire gauge you are protecting. Example a #10 Should be protected with a #14 LINK.
Notice the AMP gauge wiring. It lit up like a Christmas Tree and burned the underhood and dash wiring extensively.
Fuse Links
I can't agree more.  I had a ground issue a while back after an exhaust fabricator worked on my car.  Luckily my fusible link did it's job.  Burned out and saved the car.  Found the ground that had been left disconnected and put it back.  Put in a new link and was back in business.
Fuse Links
Yikes! that looks like a lot of work for something so easily and cheaply preventable.
Fuse Links
You got it GUYS!!! A simple Fuse link would have prevented this. We always use Maxi Fuses or links. Totally a must to protect your pride and JOY. Thanks Tom
Fuse Links
Quote from: V8Demon;390492
What is the proper way to prevent damage from the welding??
Mike
Fuse Links
Quote from: mcb82gt;390541
In the shop we disconnect the battery before any welding. Some shops we talked to dont do this and they say it is a waste of time. But i personally am not going to take the chance. We always disconnect the battery before welding on a CAR.
Fuse Links
It's better to disconnect the ground on the battery than not. Why take a chance for something so simple to do.
Fuse Links
Quote from: Kitz Kat;390802
Exactly . That is the safe way to do it. Shops complain that they have to reset things in the car after disconnecting the battery. But i would rather be safe than sorry.
Fuse Links
I heard one story from one local VW dealer shop. Someone forgot to disconnect the battery and they let the key in ON or ACC position (nobody knows why) and when they started with welding, all air bags blowed off. Unfortunatelly, the car had 8 or 10 air bags, so they were screwed :-D
In our cars the welding shouldn't do any problem, but new cars don't like it...
Fuse Links
Having had 2 Fords in flames, I disconnect the POS cable for anything more than oil changes and fuel fillups.
Seems like it's worked since then, so I reckon I'll keep to it. :)
Fuse Links
negative pole is better in cars with negative ground. you cannot short the battery when you are (dis)connecting the cable with a wrench and you accidentally hit the grounded body part.
Fuse Links
I only hate disconnecting my battery cables cause then I have to reset all my radio presets! :hick:
Fuse Links
Actually i went to a seminar about AIR BAG deployment. They warned us about the sequence of battery disconnecting. We saw videos ETC. They claim and i am not going to dispute them. Proper procedure is when disconnecting battery cables is neg first. Connecting battery is negative last. They claim if not dun this way you can deploy an air bag. They showed us video of deployment if not dun correctly.
Fuse Links
Quote from: Trinom;391397
Is it even possible to deploy air bags without key in the ignition???
100% on this the system has a power supply that has app 10 minutes or so of power with the key off. We were also warned about that. Thanks for filling this in. You are spot on and 100% on that. Thank you
