Topic: tranny transplant (Read 3286 times) previous topic - next topic
tranny transplant
I have a 198888 cougar 3.8 v6 with the aod. Id like to put another aod tranny in it. From what other cars can i get an aod that will mate to my engine?
tranny transplant
I would look hard at a auto out of a newer v-6 mustang. Should bolt up, is programable, and now semi common in junkyards.
tranny transplant
How much should i expect to pay for one
tranny transplant
And does the size of the engine the transmission was mated to matter?
tranny transplant
Any trans from a 3.8 or V8 is interchangeable. Bell housing pattern on the 3.8 is the same as a SB Ford. Watch out for the linkage coming out of the trans. Linkage is different on column shift cars than floor shift. It can be changed out, but you have to pull the valve body to do it. Transmission lengths can be different. As long as you stick with the AOD you should be OK.
tranny transplant
Quote from: Chrome;390197
You can flip the shifter shaft without pulling the valve body,done it a few times.
tranny transplant
Quote from: Kitz Kat;390211
How?? Please tell me! I'm in that boat right now. Just performed HO and trans transplant.
tranny transplant
Ditto on this, everytime I've done this I've had to drop the valve body take the huge nut loose and flip it.
tranny transplant
Loosen the the nut,1" wrench, pull out a little ,flip 180. re tighten. Like I said did it a few times. I never took the valve body out.
tranny transplant
It's been about 5 years since I did it. I may have used a ground down wrench,but I don't think so. Other guys done it to. Never dropped the VB. It' pretty simple.
tranny transplant
Still have to drop the pan though. Not fun with no lift. It can get pretty messy even with a lift if you are not careful.
tranny transplant
Having clean fluid in a "new" tranny should be done with a new filter anyways...
I didn't have any trouble getting it from the pan.
tranny transplant
IIRC theres a little round pin in there you have to knock out also. then the assy will slide out flip around and bam good to go
tranny transplant
From Eric's site:
Car(s)                              Model Years                    Direct Fit for AOD?
Fox Cougar/Thunderbird      1987-88                          Yes
Mustang V8                      1984-93                          Yes
Mark VII                              1984-92                          Yes, with modification to driveshaft length
Continental (RWD)              1984-87                          Yes, with modification to driveshaft length
MN12 Cougar/Thunderbird (including SC and XR7)1989-90    Yes
Although I would have to add the MN12 up to at least 1992 because that's what I'm running with no problem
tranny transplant
Also the panther chassis aod and f-series trucks.
Panther from 1980-91, except 1990-91 town car, both require driveshaft lenth change.
For mn-12,its from 89-97?(not sure when they went to the electronic one) v-6 and 91-93 for v-8.
Cougar bird should also read 1980-88, however the aod was optional until 1986 for the 3.8, and the xr7's and turbo coupes had no aod.
