Topic: Car moulding repair (Read 3674 times) previous topic - next topic
Car moulding repair
The moulding is coming off on the rear driver side panel. It appears to be held down by some pins (I'm sure you all know)...anyways, how do I put this back on? New clip things?
1987 Ford Thunderbird Turbo Coupe ~ STOCK
Car moulding repair
Take out the carpet and spare on the drivers side and they're like some plastic screws.
Car moulding repair
they have plastic studs molded into the moulding, with some funky nuts on them
Car moulding repair
I used some screws made for plastic and some washers to reinstall mine, been down the track many times over 120mph and they havent come off yet.:D
Donnie
10 Second NA TBird
Fredericksburg Va
Car moulding repair
Quote from: 87 T-BIRD;390001
Good idea for saving broken moldings!! I never thought of that.
Car moulding repair
Quote from: flylear45;390049
Thanks, I know when my molding pieces broke, the stud that broke off has a small hole in the center of it. I figured why can't I screw them back on.
Donnie
10 Second NA TBird
Fredericksburg Va
Car moulding repair
I'll try that!!!! Thanks!! :)
Car moulding repair
I melted my studs back on the molding you have to make sure you get adequate heat on both pieces to get a good grip
2011 Grabber Blue 5.0, 3D500 spoiler, CS valance, GT premium, interior upgrade package, Brembos, MT-82 and Whipple powered
88 TC work in progress
01 cobra: traded
Sold: 93 LX Modular 4v swap
Sean Hyland Motorsport forged rotating assembly, Teksid block, 01 cobra heads, cams and intake
Car moulding repair
I learned to glue my cat emblem in my tails, I go so fast they blow out!!
Car moulding repair
well...none of that stuff works. one of the mountings sticks through the wall so its sort of mound-like..maybe if i shaved off part of it and got some weird screw then i could get it flush to the wall..but on another spot it broke off at theres not even a space for me to screw in or anything of the like
Car moulding repair
Are you saying there is no place for it to go on the body of the car? Or that the plastic pin broke completely off?
Car moulding repair
I removed the chrome strip...drilled a couple holes where I countersunk the head of a bolt, drilled new holes and bolted the moulding on from inside.... then put new chrome stripping back on.... did the same to the front cornering lamp mouldings too.
Car moulding repair
I'm saying the little plastic part broke completely off from the trim and I'm not sure how to get it to reattach to the wall of the car
Car moulding repair
Pictures would be good so we can help you out man.
