Topic: Seafoamed the TC (Read 7665 times) previous topic - next topic
Seafoamed the TC
Smoked a lot :D
Also got a bunch of smoke out by exhaust manifold, which tells me it is leaking!
Seafoamed the TC
I have a can waiting for the Sport. Gotta get around to doing that.
Seafoamed the TC
Same here, I do this to all my cars.  Anyone else take em out and hot rod the piss out of em afterwords?  Sure makes em purr after that.
Seafoamed the TC
That was one of the first things I ever did to my car. 150k on the engine, so much smoke came out of the car. I thought I had done something terrible to my car, but after it all cleared, she idled a lot better. Throttle response was much better as well.
2002 Honda Civic EX
1984 Ford Thunderbird Elan
5.0 CFI, T5, Dual Exhaust
Seafoamed the TC
I gotta drive in a bit, so will see how it runs. I hook a hose to the intake vacuum port. You are supposed to stall car after sucking up the seafoam, there was so much vacuum, it would not stall :giggle:
Seafoamed the TC
When I helped my friend do it on his '00 Mustang, it pulled enough vacuum to crush the can.
2002 Honda Civic EX
Seafoamed the TC
This might sound like a dumb ? But I really don't know. Is there a write up or how to on how to do this correctly. I have never done it before and don't wanna screw it up.
:ford::oldcougar::mercury:
Seafoamed the TC
I have never noticed a differance, but I have always done a good service first.
Seafoamed the TC
Quote from: cougar1car;389945
If you have a sideways TB, you got to pull off a vacuum line and suck it in that way, otherwise dump in the top of a regular TB.
  Suck at least half the can in, you may have to rev it a little because it will want to stall.
 Once the amount you want is in (i use half a can) let it stall or shut it off
Let it sit for 5-10 min, then start the engine and watch it smoke like a diesel, I like to take the car out immediately throw it in second and run it to about 65-70mph WOT a few times on the highway
Then try to figure out if engine is still running as it will idle rather quietly (if it was badly carboned up before)
Seafoamed the TC
plus it tells you right on the can how to use it :p
Seafoamed the TC
I am going to do an experiment with the stuff some time in the next 2 weeks. I am going to see if this stuff is really any good with a HALF BAKED EXPERIMENT. I am not a lab so i have to test this stuff the best way i can figure out. So i have an engine with a clogged passage in the carb. I already know this from testing the engine. So i am going to use this chemical and see if it nu-clogs the passage. Just a little experiment. As you can see i am a skeptic on things like this. But one never knows. God only knows i have judged things wrong before. Thanks
Seafoamed the TC
Without putting any thought into this response, I'd have to wonder if Sea Foam is more of a carbon remover than a carb cleaner. Take a little and put it in a safe bowl, and soak a small part in it and see what happens.
Seafoamed the TC
I think you are correct VINNIE. But their add claims it can help with clogged injectors. So why not a CARB. Just saying. I will be open minded about the stuff. Been hearing so much about it. Normally i dont believe in POTIONS!!!! Just me Thanks
Seafoamed the TC
Tom, are you going to put it in the fuel tank or dump it in the carb?
I think it would be interesting if someone had a camera/scope to look in the comb. chambers before and after, for decarboning.
Mike
Seafoamed the TC
Quote from: TOM Renzo;390468
I am going to use this chemical and see if it nu-clogs the passage. Just a little experiment. As you can see i am a skeptic on things like this. But one never knows.
Post before and after pics, if you would...:bowdown::D
