Topic: 88 TC Vacuum line routing T3 stock IC manual boost controller (Read 2514 times) previous topic - next topic
Need the correct turbo vacuum line rounting: 88 TurboCOupe, just installed a T3 using stock intercooler and homemade boost controller.  Having trouble figuring out what to do with the lines going to the IC.  Do I keep the stock line coming from the vac. tree on the IC? What about the other nipple on the IC?
87 TC (southern car)
88 XR7(Mustang front brake upgrade)
78 F250 Supercab (southern car)
76 Marquis (southern car)
71 XR7
89 Escort GT (southern car)
there should be a diagram on your fan shroud cover
Post a photo. But the vacuum line aspirator if you will at the bottom of the stock inter cooler can be plugged with a 1/8 pipe plug. According to ford it is an aux. vacuum source for the cruze control. I have dun some messing with it and did some readings on it and in my view is a waste of time. Remove the fitting and plug it off.
