Topic: Power Seat Motor (Read 1765 times) previous topic - next topic
Power Seat Motor
Looking for a good drivers side power seat motor.  Mine has the 6-way seats if that makes any difference.
From what I've found online, I believe it to be a part #:E6SF-14547-BA.
Power Seat Motor
I have a couple sets of power seat tracks. I'd be willing to pull one apart for you. Do you know how to test it? I'm getting a roof put on my garage and everythings covered up at the moment so I cant get to it right now but if you can wait I'll let you know when I can.
Power Seat Motor
OK no big rush.  Yeah I need to pull the seat and check the motor and tracks out.  It could be that the tracks are gummed up and the motor is just weak enough it won't move it.
Power Seat Motor
I probably have one or two in the garage.  Probably an earlier motor, though.
Power Seat Motor
Chuck do you know if the older 83-86 tracks work on a 87-88?  I did notice they are different part #'s so I was not sure.
Power Seat Motor
Quote from: 50tbrd88;389492
Couldn't say offhand.  My newest one has been an '85.  I don't see why they wouldn't.  Floor pans are the same, and the seats would bolt up.  Might be a connector difference, or something of that ilk.
Power Seat Motor
Thanks, I agree I don't really see what would be different.  I've found some for sale but most seem to be the earlier part #.
Power Seat Motor
I had 87 power seats swapped into an 86. Can't remember if I did any wiring work though.
Power Seat Motor
Chuck do you have a 83/84 passenger side track and motor? i wanted to convert my passenger manual seat......
Power Seat Motor
ive got 6 way power drivers seat in my 88, id like to put one on the passengers side as well...anyone/anywhere i can get a motor and tracks?  and how difficult is it to hook up, if i have a switch already?
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
Power Seat Motor
I have a 1986 mercury cougar and the seat switch doesn't work. I am not sure if i just need to get a just a Seat Motor or a Reclining Seat Motor. Does anyone know?
