Topic: Had the Turbo Coupe on the dyno. (Read 2290 times) previous topic - next topic
Can you say "Oh No!"
http://www.youtube.com/watch?v=Czvo-w5ZwMg
Time for turbo removal.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
*frown*
So what did it put to the ground?  Smoke and all...
Travis
Sharp looking car. Were you running 20 PSI on that run?
Quote from: turbotrav;389306
Travis
It's in text below the video.
Travis
201 rwhp / 283 lbs torque.
For those of us that don't want to watch a video. :D
...and there was light!
Yeah, py numbers, I was expecting better. Anyway turbo is out, getting ready to take apart and rebuild it, if it's worth rebuilding. It appears I was bleeding boost thru the the turbo, that would account for my low HP.
Of course I don't think the car was fine tuned yet.......
Next time I better have some better numbers.
Oh and it was at 20 psi, probably 10 through the turbo and the other 10 through the motor LOL
1985 Thunderbird TC
What are your turbo specs and cam ?
The TR7 put down 288/320 with a stage 3 .60 T3/ TO4E Turbonetics and a mild re-ground Ranger roller cam with bone stock internals. Just new springs was all.
You should do similar (if you have enough fuel). I also have big injectors and MS fuel/spark control.
