Topic: more Caprice woes. Update, opinions please. 6-26-12 (Read 2448 times) previous topic - next topic
AIR FUEL SPARK, which one is missing?  If its too much fuel the plug would be wet, If I were you Id pull a plug and see what it looks like.  I hate the opti-spark.  If you decide to keep the car A lot of guys drill out a grease fitting to make it hollow and then install it in the weep hole.  This diverts the coolant from the distributor in the event of a water pump failure.
Love Foxes, Birds or Stangs.
Electric water pump cures the issue along with a waste spark system. If you really want to get fancy the LS 1 computer and COP is the best answer bar none. That completely eliminates the OPTI SPARK and uses trigger control. But i am not buying the shops diagnosis one bit. He clearly has the answer as he wants to buy the CAR!!!!
