Topic: Fuel sender and aftermarket gauge (Read 1433 times) previous topic - next topic
Ok I think I've asked this before but I can't find it and I apologize if so.
Any one know the output of the fuel level sender for 88 TC, and is there an aftermarket gauge that will  hook up and read correctly? Without a new sender.
According to the 88 EVTM, the manual gauge vehicles fuel sending unit readings would be, (60-86 ohms is empty and 8-12 ohms is full). I did some looking on the Summit Racing website and found several different types of gauges, this is one of them by Auto Meter(ATM-4315) its a 2 1/16 diameter gauge. 73 ohms reads empty and 8-12 ohms is full.
Donnie
10 Second NA TBird
Fredericksburg Va
Quote from: 87 T-BIRD;389151
+1 Spot ON
ty ty
Will look at getting one and building a cluster now :)
Quote from: TOM Renzo;389157
+1 Spot ON
Thank you Mr. Tom
Donnie
10 Second NA TBird
Fredericksburg Va
You are very welcome 87.
