Topic: console lid/interior refurb (Read 4530 times) previous topic - next topic
easy way to take a ripped up, cracked and otherwise disgusting console lid and give it new life.. any idiot can do it, even if you lack any kind of upholstering skills.. i'm not an upholstery pro, but i do wrap things in tweed quite often
this will probably be a lot easier using vinyl, for a stock appearing refurb, as it is a little more forgiving with a little steam.. if your padding is trashed, you can se the remainder of it off and replace it, as well
basically, all you need is..
- the material you wish to use
- headliner glue/spray adhesive
- chalk or marker
- razor knife/blade
- philips screw driver
bare with me, i forgot to take 'process pics,' but you should be able to figure it out very easily
before:
after:
Tweed sure does look a lot better than it sounds. That looks real nice... or at least if it goes with anything else in the car.
it will.. i'm doing an insert on the door panels, the arm rest pads, my rear deck carpet and maybe some other odds and ends.. i'll probably end up doing the pillars and kick panels too, but that's after i get more tweed.. i only have half a yard of it right now.. thought about doing my headliner, buuuuut that's just too much IMO
Quote from: Shadow;387789
Sufferin suckatash! It's Tweedy bird!
i should have seen that 1 coming.. lol going to do the dash pad, too.. it's cracked, so screw it
I did mine in leather a while back
do you agree that it's insanely simple and even the dumbest of people can do it with excellent results? i don't get why people go crazy over finding console lids that are undamaged, when they could easily refurbish their own
you used the same adhesive i did
i did the removable piece of my passenger door panel.. i love the way it meshes with the blue.. definitely going to pull the carpet off the bottom and replace it with tweed.. will definitely bring the whole panel together
Looks real nice!! Is that regular furniture upholstery material??
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
I was actually thinking of doing the same thing to my spare lid to see how it turned out. I wasn't thinking tweed, but basically the same idea. I just don't like the way the factory vinyl feels under my usually sweaty arm lol.
Isn't the factory stuff leather? The one in my T-bird is.
Quote from: thunderjet302;388029
 The thin ones are , the thick ones are vinyl
meh. leather, vinyl, I don't care it all gets sticky and hot in the summer just the same.
Sarjxxx, you definitely want a cloth cover. That way, when you're really sweaty, it'll soak up in the console lid cover so it can smell like a gym locker later on.
