Topic: 88 turbo coupe (Read 2730 times) previous topic - next topic
88 turbo coupe
I just bought a 88 turbo coupe tbird. I was wondering if any of you knew the wheelbase, and what rearend was in it? I was told it's a limited slip 8.8, and it's 104 inch wheelbase. Just checking to be sure. Thanks in advance.
88 turbo coupe
Ok cool, I hear it has a borg warner t5? It had a 3.8 turbo in it too.
88 turbo coupe
Quote from: Vito324;387526
No, no it doesn't.  2.3T I4.
Wheelbase is 104.4"
88 turbo coupe
It had a turbo 2.3 and the tranny is a WORLD CLASS BORG WARNER T5. And the final drive is an 8.8 ford POSI.
Chuck is correct on the WB and engine. The rear axle is 61 inches wide DISC TO DISC
88 turbo coupe
Ok, Thanks guys. Just wondering, How much is the T5 worth? I may not sell it.
88 turbo coupe
Quote from: TOM Renzo;387537
It had a turbo 2.3 and the tranny is a WORLD CLASS BORG WARNER T5. And the final drive is an 8.8 ford Trac-Lok.
Fixed for ya ;)
To the OP: did you pick it up to resell, or what? Or are you just selling the 2.3 T5?
88 turbo coupe
Actually, I picked it up to put my stroker 347 in it.
88 turbo coupe
Nice.  I have completed the swap.  If you have any questions, please let me know.
88 turbo coupe
ahem.... :ttiwwp:
88 turbo coupe
It's a WC T5 for sure but is 4cyl spec, which means it a bit on the weak side(240ft lb I believe) and has a stump pullin' 3.97 1st gear... Input shaft is slightly different than the V8 T5, requires a Probe pilot bearing to use... None of the gears interchange with the V8 pieces, even the case is machined differently due to having a larger gear size on the input shaft...
A '88 TC with T5 will have a 3.55 ratio, 8.8" Traction-Lock rear with disc brakes... The disc setup are unique to the '87 & '88 TC, At one time Ford Racing offered this setup as a conversion for the Stangs but it's long been discontinued...
88 turbo coupe
^^^Thanks for the info. I'll post pics when I get into the project.
88 turbo coupe
How much is the T5 worth in these?
