Topic: interesting body mod (Read 2485 times) previous topic - next topic
i literally stumbled upon this.. when i bought my 4 eyed front clip from BJL, he gave me the front lower halves of the fenders with it.. well, for some reason i decided to do body work today and i started attacking the rust on the driver side 1/4.. i cut the patch from the passenger side fender chunk and trimmed it to fit the hole.. it actually steps the wheel well arch out at the bottom a bit, giving it a little more 'flare.' it really looks badass in my opinion, compared to the original, which begins to 'tuck in' with the rest of the lower 1/4
it's a subtle mod that almost no one will notice, but i think it really makes the flow of the rear 1/4 panel and wheel well arch look a little more aggressive and 'stylistic' (for a lack of better terms lol)
That's an interesting little mod. I like it.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
i'm going to get some better shots of it in a little while.. i'll snap some of the unmolested passenger side for comparison
alright, some more pics.. i wish i had white paint, it would show the actual fitment a little better.. the black makes it look like it has a giant crease, when it in fact lines up perfectly and flows fairly well
passenger side for comparison.. and for reference, both rear tires are the exact same size cooper cobra radials.. you'll see the majority of the difference by paying close attention to the vertical tread grooves
you can tell by comparing the area of the tire each side covers
the section of the fender chunk i'm using for the passenger side.. since that side is in better shape, i'll take some good before, during and after shots, to better show how well the piece really fits into the 1/4
i pray yours isn't as bad as mine.. my whole lower 1/4 is covered in filler.. i'm not grinding it off to find out what's under it.. i'm afraid to see.. lol
No theres not really much filler in mine that I can tell so far. Behind the wheel wells on mine is pretty good, its in front of the wheel wells I gotta do some work on!!!
i have work to do there, too.. the whole panel, from the impact strip to the rocker seam, door jam to wheel well :(
Mine isnt quite that bad, but now I have a whole unusable hood (as a hood any how!! ) that will work great for flatter areas like that!!! I guess getting in the wreck may have some good come out of it for me!!
LOL blend the scoops into the section between the wheel well and door.. brake cooling win! LOL
The thought has crossed my mind!!! I dont need any more temptation than I already got going thru my own head!!!!LOL
Very subtle, but looks a lot better, I like it
