Topic: explorer throttle body (Read 1526 times) previous topic - next topic
I was wondering if a explorer 5.0 TB will work on a turbo coupe?
Yep.
But you'd have to bolt the rest of the engine in with it to do you any good...lol
Quote from: ThunderbirdSport302;386657
Yep.
Hahahaha!!!
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
I think it is the same as a early 302 T bird isn't it? 93-94 ish
if so it will with some mods and look like this
Quote from: Soul;386666
Nope, not the same. The 5.0 Explorer TB is setup very similar to the 5.0 Fox Mustangs. The TB you want is the Supercoupe, 94-95 5.0 Stang, or the MN12 5.0 Bird/Cougar unit.
hey John, were you able to find that supercoupe one you thought you had laying around the garage?
John?
Hey, SR71blackbird, empty your PM inbox.
Hey Jangus, I emptied my inbox.
