Topic: Plans for my new garage... any architects or structural engineers present? (Read 3056 times) previous topic - next topic
So even though I dont actually own my new house yet (May 31 can't get here fast enough) I'm already planning on building my Garage-Mahal. It will be 32 X 28 with 12'6" ceilings to accommodate a hoist. The bay doors will be 8' wide X 10' long. I've been doing some drawings to get an idea of what I'll need by way of materials. I've tried to detail the framing as accurately as possible (roof truss details aren't shown because that's up to the truss manufacturing company). I'm not a carpenter but I have some idea how to build a building, having built the family cottage almost entirely by myself. Just wanted to check and see if any architects or structural engineers are present and have any input. Here are my drawings so far (sorry for the small size, I had to reduce 'em to upload 'em):
Front elevation:
X
Left elevation:
X
Right elevation:
X
...and the rear elevation:
X
Here are some enlarged framing detail drawings:
Front:
X
Left:
X
Rear:
X
Right:
X
run the plywood sideways...it makes the walls stronger
roof too
like so....
here look though my photoshop folder of my garage addition
http://s233.photobucket.com/albums/ee79/daminc/our%20house/Garage%20addition/#!cpZZ2QQtppZZ28
also put another wall plate under your walls... use treated lumber against the concrete
I'd run your peak the other direction.....that way snow won't pile up in front of your doors and you can always blow the back wall open and add on easier.
1988 T-Bird Sport Coupe--5.0 HO, MAF swap, 1-5/8" shorties, BBK/Flowmaster exhaust, Explorer intake, 70mm Edelbrock TB, T5, B&M short throw, Centerforce clutch and PP, disc brake TC rear w/ 3.55's, TC front brakes, '98 Cobra springs, DIY SFC's, other misc .  14.05 @ 98mph with launching too low and shifting too high.
OK, will do. I knew the sideways plywood thing on the roof but didn't think about the walls. I also knew about the pressure treated bottom plate but didn't know about doubling it up. That's cheap enough to do...
I can't see your photobucket gallery, only that one photo. Did you build that addition on a slab or on footings with a frost wall? I know our local building code requires an engineered slab for anything over 600 square feet, and our code is likely similar to yours since we have similar climates...
I changed the link ... can you see it now?
It's an a slab with a 12x12 haunch footer around the perimeter.. all 1 pour
Quote from: Dan B.;386326
Where this is going to be built adding on to the back won't be an option, as it'll be the 6' minimum from the property line. It would be possible to add on to either side, though, should I ever see the need (even for something like a car port for winter storage of the Thundercat I don't even own yet). Snow shouldn't pile up, since I'll be using ashphalt shingles and snow generally doesn't slide off of them...
Jerry, when I click on the link I can only see that one photo. No option of scrolling through other photos
For my slab I'm going to have a contractor do it. Hopefully he'll do it to code (at least he will if he wants to be paid). I'll need at least 6" thickness for one side, to allow for the hoist
here is the link to the album.. it should show all the pics on it
Also, Jerry, did you frame yours with 2X4 or 2X6? I think local code requires 2X6 for a 12' ceiling height, but I have to find out for sure. I drew my plans for 2X6 just in case, but 2X4 would be a lot cheaper, both for the studs and for the insulation (R20 is much more expensive than R12). I know 2X6 would be better for heat retention, but it'll only be heated for a few hours a year anyway, and with a wood stove...
