Topic: post some videos of your bird (Read 4523 times) previous topic - next topic
what if you have a Cougar, and not a bird?
Quote from: daminc;386206
post em up :roxor:
Ok heres mine just before I put on my drag radials.
http://www.youtube.com/watch?v=Hwr1yYOPAUA
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
mine with open headers
http://www.youtube.com/watch?v=hN4nMna8FkY
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
bet you guys didn't think a 3.8 could do it did ya
[video=youtube;ajP4j6hhZ2s]http://www.youtube.com/watch?v=ajP4j6hhZ2s[/video]
Quote from: 347Thunder;386268
dude that is so cool that your wife likes to drive your car. Mine will barely sit in it
She drives it harder then I do.lol
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
This is my best effort.....all though that was a couple of years ago.
http://www.youtube.com/watch?v=kGsz7PdEqTI&context=C4e10c76ADvjVQa1PpcFNryTMAmMs0RUrfz0_ugls_WxXs4Tq6M2g=
The car has changed abit visually and now swapping in 351 turbo.
Travis
Thats pretty impressive^. I figeured the XR7s or TCs would need a lot more work to break 12s.
Skip to 5:40 to jump over the boring :giggle:
[video=youtube;iEoE4Nw_L7M]http://www.youtube.com/watch?v=iEoE4Nw_L7M&list=UUP8nfr2dUehLVFkzm7042Gw&index=3&feature=plcp[/video]
Quote from: bryan163;386558
'It didn't happen over night.  But with lots of boost (27psi from the stock turbo)  The XR7 made pretty good power.  It was pretty easy to launch.  Lots of 1.7's 60' which really help getting into the low 13's and 12.96.  I figured it made 275 rwhp.  Not bad from stock stuff.  Think about it.  At 9psi(stock for 86 auto 2.3turbo it made 120rwhp)  I had a pretty good methanol injection, intercooler, drag radials, and wideband so I could tune with the limited options I had back then....ie boost, timing, fuel pressure.  It made decent power....but a one trick cat...ie WOT.  I couldn't have over 5 psi or I had knock.  I ran the car with lots of base timing.  IIRC 15.  The 2.3T is a great engine to make good power from fairly cheaply.  I wanted 11's in my fat cat.  That wasn't going to be easy.  Hence the 351 turbo swap.
Travis
