Topic: Broken Tansmission :( (Read 1461 times) previous topic - next topic
I think there is something missing in there!
...and there was light!
Yikes. I feel your pain. A couple of months ago my AOD refused to shift properly even though it was just rebuilt. They found metal shavings in it and had to gut it completely and start from scratch. $$$ :(
The only silver lining is that it's tight now like when it was new, basically because it is at this point...:punchballs:
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Whats that in?  That is certainly no normal car transmission I've seen.
Straight cut gears? Three shafts?:dunno:
hmm.. my guess is lawn tractor.. some of them have straight cut gears because you can go all speeds in reverse
I feel your pain as well, I'm going to be fox-less. You ever has the time to do it right, but always have time to do it over...:shoothead
Lol it is certainly not a lawn tractor! It does however have a torgue rating of 1550 ft lbs! Lol
Couple more pics.
Ahhhh good ole' semi-truck tranny
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
well when you take a pic like above, it's a little more obvious on the actual size of the trans lol
