Topic: aem wideband (Read 4524 times) previous topic - next topic
aem wideband
i have a 1988 thunderbird turbo coupe and im planning on getting an aem wideband to see where im at cause i did turbo intake and straight pipe exhaust and plan to do alot more but i wanna make sure im good as far as that goes. does anyone know how i should go about wiring i dont wanna RIG anything im very very neat with my work i wanna do it the rite way but i figure i ask im sure you all on this site feel the same way about this. i dont have a honda anymore.. finally getting into the big boy toys now ;)
aem wideband
I just got the power from the fusebox using an add a circuit thing from the parts store.  Quick, easy and totally reversible.  I love my AEM btw.  I mounted mine in one of the vents as seen below.
aem wideband
@Loaded87IROC    that looks sick... ive been looking does that gauge pod thing from the fox body mustang fit above the radio.  it holds two gauges. i think on the fox it goes where the vents are supossed to be at. and what pillar pod works for our car that fits perfect i heard 94 mustang one does is this true. i searched on here but no clear answer
aem wideband
Thanks.  It only took a few hours to make it.  The Mustang gauge cage won't work in our cars because of the different vent layout.  Some people have made gauge panels for the spot above the radio if you don't have a factory EQ in that spot.  The 94+ Mustang A pillar gauge is the one that fits the contour of our car closest.
Edit: Look at the following link at NATO for a short pillar gauge install.
 http://www.turbotbird.com/techinfo/PeteG-Pod/PeteG-Pod.htm
aem wideband
Here is a pic of my buddies gauges in his Mustang and one of my dash to show how different they are.
aem wideband
Quote from: Loaded87IROC;385211
it's almost like looking at my interiors.. DIRTY AS HELL! lol
here's where mine is.. i didn't put it there, but i would have done the same thing, as i hate the look of that stupid clock
aem wideband
I thought about using the clock spot but I love my Tripminder too much, lol.  I keep the 85 pretty clean but I rarely clean the turbo car as it rarely gets driven.
aem wideband
Okay where your friend has that peice  that's what I want and I wanna put it above the radio it's empty. Will it fit there?
aem wideband
I don't think one of those will fit in that spot.  You will probably have to make your own, which shouldn't be too hard.  I made delete panels for my radio and HVAC out of some acrylic sheet.  You could probably do something similar with holes for the gauges.
aem wideband
Check out this link for some more ideas.
 http://www.coolcats.net/modifying/gauges.html
aem wideband
Thanks man you have been a great help
aem wideband
Just another way of mounting gauges that worked for me.
aem wideband
This one shows the mounting of my AEM near the shifter. I just put it there to tune and plan to move it to another car when I tune that one.
aem wideband
@quickshift I like that I would like to mount them on my Column what did u use to mount them there what kinda pods cause I know there is a curve there
aem wideband
I mounted the tach, and used this  http://www.jegs.com/i/Auto-Meter/105/2204/10002/-1?parentProductId=745207  to mount my vacuum gauge  using SHORT screws directly into the plastic column cover.  I thought this through long and hard as once those holes are made, they're  forever. I run a carb on all my toys and rely heavily on both vacuum and my AEM for the ultimate tune under all conditions.
