Topic: Door handle cups.... (Read 1221 times) previous topic - next topic
NOS gray door handle cups (left and right) for '87/'88 base door panels. Mint, in the Ford bags.....$40.00 shipped
NOS Ford tilt lever. In the Ford bag......$25.00 shipped
Bump. Needs a loving home.
would they fit on my 88 cougar?
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 3.8 V6 - Rescue
1988 Cougar LS - Cinnabar/Rose Quartz Metallic two tone - 5.0 V8 - Survivor
Yes, if they have the standard door panel. Got a pic of your panel so I can verify?
nevermind...I just re-read and realized they were grey...my interior is brown.  Unless...are they the dark bluish/gray color?
I have one in dark blue. These are wicked hard to find. Most people just paint them with interior paint to match the interior color.
you can do that?  how?  I dont even know the technical name for my interior....and I thought that if I tried to paint them myself they'd just turn out junky wouldn't they?
I used interior dye to color my dashboard a year and a half ago, and my console, glove box door, and speaker grilles. When done right (proper prep), it'll last forever and I even use cleaning products on the dash (vinyl protectant) with zero issues).
If they don't fit your needs, no worries. I'm just trying to help. I know how hard it is to find missing and needed pieces.
no no thanks...If I can be convinced that itll turn out right Ill buy yours and dye them...I just havent had luck with painting things...they always end up with specs and imperfections
I prepped mine by simply cleaning them with an alcohol pad, letting them air dry for a while, spraying them lightly with adhesion promoter, a light light coat of primer, then mist coats of the dye until I got the coverage I wanted. Looks factory.
Interesting...hopefully it'd work for me...I know I just spent the time repainting my rear opera lights with some chrome spray paint...and no matter how must care I put into it there was still speckles on it...maybe the trim dye will be better quality paint
