Topic: 88 XR7 5.0 Hairpin Clip Push Connect for Fuel Pump Gas Line Part Number? (Read 2158 times) previous topic - next topic
The plastic Hairpin Clip Push Connect Fitting from the return gas line/vent line to the fuel pump broke off the line when I dropped the tank to replace the fuel pump.
]http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c1528006b9d3
The Autozone sales rep sold me this http://www.autozone.com/autozone/parts/_/N-6o3is?itemIdentifier=238623_0_0_ but it's not right.
Does anyone know the correct part number or where I can order?
Thanks,
Dawn
Quote from: dawn0124;384574
I am not entirely sure what you are referring to, but the push clip in the link above looks like the same clip that holds the fuel pressure lines to the fuel filter on an 1988 TC. If it is the same clip, new fuel filters come with two of those push clips.
...and there was light!
You can get those clips at any part store.  For sure NAPA.
Mike
They have an assortment pack of 5/16 and 3/8
http://www.autozone.com/autozone/accessories/Help-6-pcs-5-16-and-3-8-in-Ford-fuel-line-retaining-clip-assortment/_/N-25gi?itemIdentifier=429540_0_0_
Help/6 pcs. 5/16 and 3/8 in. Ford fuel line retaining clip assortment
Part Number: 800-015
Save a horse, ride a Cougrrr!
1988 Mercury Cougar - 5.0HO, 3G, AOD w/shift kit, 4.10 gears in 8.8, Mass Air, CAI, Pypes X-pipe, Pypes 2 1/2" exhaust, Pypes Violator lers
1997 Ford Mustang GT - stock
2000 Ford Ranger 4X4 4.0 - stock
2001 Mercury Grand Marquis- stock
2008 Ford Escape 4X4 - stock
Thanks all, ended up pulling the plastic lines, replacing with real fuel line and clamping the ends.
