Topic: Getting close giggity (Read 1042 times) previous topic - next topic
Almost have the 306 ready to drop in
87 TC
ooooow, looking perdy!
What heads are those?
Cheep eBay engine works basically procomp
87 TC
It looks like you have used them on a previous motor. Do you like them?
Looks great BTW!
Picked them up used for $300 thought what the hell ill give em a try. I'm gonna strap on my p1sc and run around 8 to 10 lb of boost don't really want a full out drag car just a nice streatable car with a little giddyup.
87 TC
did you have them checked out/do you know if the previous owner had them checked/resurfaced? i've installed the procomp heads for customers and it's a good idea to have a machine shop look them over.. my first set, i was a bit skeptical and it paid off.. 1 head was perfect, the other was a little wavey along the intake surface
That sounds like a sweet deal to me! Shadow does bring up a good point though.
