Topic: No spark.. (Read 1526 times) previous topic - next topic
No spark..
86 3.8 throttle body, 380,000miles<----unreal
The other morning I started the bird and returned to house as normal, I went back out to go to work, and the car had shut off, trying to restart it did not work..it just turned over. After several tries I started smelling gas...so I assumed a no spark issue. had to take the 86 F150 to work....
So i get home from work and tried to start it again but same issues. I removed coil wire from distributor cap and found a ton of oxidation...I cleaned this all up...still no start...no spark..I replaced cap, rotor, and coil(the coil was the original).....but I still have no spark. I did unhook battery overnight....but the Bird will not fire....Help and thanx
JByrd13
No spark..
TFI failure?
No spark..
I did verify no spark with a timing light on #1 wire....(dang thew a good coil out).....Is the TFI the module on the distributor that the electrical connector is plugged into? ,and can this unit be checked...and if so how?(Thanks for quick response!!
No spark..
Yes, the TFI is on the distributor.  I've never checked one but i found this link
 http://351winsor.com/joel/Ignition_Systems/tfi2.html
No spark..
Looks like good stuff...but its getting late here  I will start troubleshooting that  tomorrow 4:30 EST    I greatly appreciate the help...I will be posting tomorrow and let you know what I found!!  JB
No spark..
i would run a CEL code test.. see if it threw a code before it died
No spark..
TFI.... PIP>>>> Check coil key on voltage. If it is their  disconnect the ECM plug crank it and that will confirm it. If it still does not have spark with the ECM disconnected pull the DIZZY and rebuild it.
No spark..
Sorry about the lateness getting back...but I wasn't able to work an the car  while pouring down rain.....Anyway  you guys are good!!! checked for PIP , was not there...I ground down a craftsman 7/32 deep-well socket slightly so it would go deep enough to get a bite on the machine screws. We were able to remove the TFI while the disturber was still in place. We then ohmed a few things out using this as reference  http://351winsor.com/joel/Ignition_Systems/tfi2.html    It showed a problem between A and D6 and B to C. Took TFI to AutoZone....Missing PIP fail....Replaced TFI with new ($48.and some change)....the Bird is back on the road!!!
Thanks much
JByrd
