Topic: Explorer Upper Intake Question (Read 1412 times) previous topic - next topic
What is the diameter of the bore in an Explorer upper intake?  Is it 65mm, or 70mm?  I thought it was 70mm, but wasn't sure.
William
Should be 70mm. I've seen a few china ones vary somewhat.
Thanks Kitz.  I've already got a 70mm EGR spacer.  I plan to buy a 70mm Accufab TB this summer.  That should work well.
William
It's probably a bit to much for a stock motor,but I don't know what you got either.
I've got a fresh 5.0 with GT40P's, Explorer upper/lower and a TFS stage 1 cam so it should work nicely.
William
That's a go,sounds good.
Didn't they COME with 65mm TB's? What the hell!! I guess I never really looked that close :crazy:
Not that you're gonna lose 20 horsepower from that little decrease in the opening lol
Yep.  You're right.  Explorer came with 65mm TB's.  Depending on your combo, worthwhile gains can be had by upsizing to a 70mm TB and spacer.  I ultimately want to use 24lb injectors.  Since I was planning on buying an aftermarket MAF (like a C&L), I'll get a larger one that's calibrated for the 24lb injectors.
William
You did say Cobra intake, There is a difference. I edited this to say you don't need a spacer for a cobra!.
Quote from: ZondaC12;384130
The front of the Explorer TB is 65mm. The backside and the opening to the intake are both 70mm.
1986 TC 100% stock
1983 TC modded (sold) :(
"nitrous is for guys who can't build motors"
Quote from: Kitz Kat;384140
Who said Cobra?  Not me.  :)
William
Quote from: 88 Blackbird 5.0;384156
DAH,I'm stupid. I don't know where I got that,sorry.
