Topic: 4 eye header panel (Read 1440 times) previous topic - next topic
4 eye header panel
Is it possible to put use a 4 eye header panel on an aero car? without using the 4 eye bumper?
4 eye header panel
Yes, but he used the 4 eyed bumper too, so now there's the moulding mismatch.
4 eye header panel
yes, it's possible.. does it look good? NOOOO.. someone posted a link or pic of 1 and the bumper clashes with the header and it just doesn't fit quite right
4 eye header panel
you mean these?
This guy has since put the correct header back on and it looks much better.  If you do the four eye, you pretty much have to go with the 4 eye bumper because the top holes on the bumper cover on an 87/88 are covered up by the 83-86 header just about.  You can see in these pictures how much he had to push down the bumper cover and I don't know if he ground the bottom of the body line off his header or not to get it to fit at the corners.
4 eye header panel
beep beep, that's the 1! for some reason, i kept thinking it was hypostang that posted it
4 eye header panel
hmmmmm but the aero lights are so hard to find, but the 4 eye the molding wont match decisions decisions
4 eye header panel
things would be so much easier if these bumpers didn't have the stupid impact strips molded to the bumper.. would make for a much better look, too
