Topic: Problems after TB change (Read 706 times) previous topic - next topic
So after i changed me throttle body, the car is revving up higher when cruising and shift hard into the next gear. Im 99% sure its the TV cable. can i adjust it to get it to shift right?
Here you go.
http://www.youtube.com/watch?v=6L3hNzxdiYw
Oh sweet thank you Bruce!!
