Topic: Need TC airbox pics (Read 3220 times) previous topic - next topic
Need TC airbox pics
Quote from: 87thunderbirdBlackJack;383229
Do you need the plastic ducting for under the hood? I have one on a TC hood I have here ifya need it
I got it somewhere, I was looking for it today.. Not sure if it can be used anyway..
Lou, there are actually a lot of cars that have used hood scoops.... I see that camaro had a working hood scoop and airbox
maybe it was a firebird
Need TC airbox pics
Im pretty sure he wouldnt drive it in the rain, but if you put a couple holes in the air box it should drain ok.
Need TC airbox pics
Eh, most cars suck some water at some point in time.  But the way Jerry is looking at doing it (just by the looks) he's going to have the ducting go to the airbox, which has a filter, and if he taps the furthest point of the airbox and puts a drainage nipple and a hose leading out it should do fine. The factory airbox where it dumps out behind the bumper cover still gets wet. the filter will catch 90% of it and if you run the fancy K&N filter it in theory should have no issues.
Im ,eventually, going to chop one of the ducts I have here and make it dump straight into the aircleaner. Iz gots no worries.
Need TC airbox pics
to be honest just buy a fender well cold air intake for it. mac preformace parts makes a nice one. they clam 14hp gain on dyno with hood closed and its only around $150 and u get chrome tubing. ohh if u didnt know u have to buy one for a fox body stang it will fit there the same under the hood
Need TC airbox pics
That's pretty much what I have now using the stock airbox... mines wide open in the fender
$150 is a lot of money for 20'' of tubing, and a filter if you ask me.
It just wouldn't be "Project Evolution" if I couldn't make it, mod it, or re-build it....;)
Need TC airbox pics
you need the air box off a cervinis ram air hood.... you could move some stuff around to make it close
https://www.cervinis.com/product.aspx?car=1&id=1122#8006
2011 Grabber Blue 5.0, 3D500 spoiler, CS valance, GT premium, interior upgrade package, Brembos, MT-82 and Whipple powered
88 TC work in progress
01 cobra: traded
Sold: 93 LX Modular 4v swap
Sean Hyland Motorsport forged rotating assembly, Teksid block, 01 cobra heads, cams and intake
Need TC airbox pics
Too bad that won't just bolt up to a TC hood.
Need TC airbox pics
I saw that kit..... it really gave me a lot of ideas on how to make this actually work
Need TC airbox pics
any progress.  I've been thinking about the same thing, and have been making designs on how to make something like Cervini's.
Need TC airbox pics
I didn't have time to make a template for the plastic guy. Had to fix a few things on my car first. I have more motivation to get it on the road first. It's very close. Then I can play with a few ideas I have
Need TC airbox pics
Quote from: ja;383267
Man it would be nice to have that kind of aftermarket support! :nkhk:
...and there was light!
Need TC airbox pics
to be honest. i don't think it'll really do anything for a stock-type EFI car.. all the bends required to make it work will take away all the aspect of the ram air idea.. at each bend, the air will begin to lose velocity, to which point the motor will just start pulling it through like a typical intake.. now for 87thunderbirdBlackJack's car, it's perfect because he's running a carb.. if he can get the scoops to seal to an air box type breather, he should see some gain anywhere above 35mph
Need TC airbox pics
I never said it would do anything for performance.... just want to try to make them usable, that's all
It would still be better then a cone filter in the engine bay suckin in heat, like a lot of people do
Need TC airbox pics
true, but unfortunately the duct work being over the motor will heat up and warm the air.. not as warm as the typical cone filter laying on the wheel well, but still warm
Need TC airbox pics
I can foil line it..... instant radiant heat barrier
