Topic: Throttle body help (Read 2243 times) previous topic - next topic
Throttle body help
Im trying to take off a throttle body and im running into a problem. How do i take this orange piece off?
Throttle body help
I dont want to do it wrong and break the piece
Throttle body help
Wow , I haven't seen one of those intact in years  , I believe it just pops out with some downward force
Throttle body help
The bushing shouldnt come off unless you need it for the another TB. I use a flat screwdriver and pop the tv cable out of the bushing. If it were me, Id leave the bushing and get a new one if I needed it for another TB.
Throttle body help
I need to put this on a different throttle body. So i press down in the middle of it with a screw driver or do i put the screw driver under it and pry it?
Throttle body help
A door panel trim tool works for popping the linkage off. Like said use a new bushing,you can get brass ones from ford.
Throttle body help
You can also get a new bushing from the "Help" section of Napa
Throttle body help
Those plastic bushings are pr0ne to breakage, letting the TV cable drop and then...burnt up tranny. I found out the hard way. Get the brass one.
Throttle body help
ok im calling up ford now! thank you very much for the help!
Throttle body help
They said they dont know anything about a brass one but they have a plastic one
Throttle body help
Quote from: SR71blackbird;383077
 Call a different dealer ....with this number F3SZ-7H303-B
Throttle body help
Okay thank you very much!!!
Throttle body help
If you can't get it I got extras I can mail you one. When I bought mine from Ford they sold me a 5 pack,I guess they will last 5 life times.
