Topic: multiple cranks required to start (Read 2073 times) previous topic - next topic
So I have a few questions about some little things with my car.  Nothing big, but if anyone who knows more than I do has input, fire away.
First up: Starting.  It used to be that the car would fire up after only a second or two of cranking the starter.  I mean always.  It started so easy.
But then the car sat for 3 years and was only started a couple times a year.  Now when the car is cold I almost always have to crank 3 separate times before it takes off.  After it warms up it will sometimes start with one crank but usually it takes 2.  The weird thing is it seems to have more to do with the number of times I crank than it does with the length of time.  Maybe I am crazy but it seems to start better with 3 short periods of cranking than it does with 1 long one.
Anything I might be able to do to get the thing to start a little easier?
Since it's been sitting for 3 years maybe your battery is going?
I'd say you've probably got a leaking fuel injector or a bad check valve in the fuel pump. The fuel system is losing its prime. In essence it's like running out of gas every time the car is shut off, and you need to refill (or repressurize) the fuel lines. Each time you turn the key on the fuel system primes itself, so the multiple tries would build up the prime quicker than one extended crank.
Quote from: Thunder Chicken;382127
That would be my thoughts as well. Fuels turn Varnish and cam play havoc on check valves and fuel system parts. I would install a pressure gauge and monitor the fuel pressure to see if it looses prime pressure. Thanks
Try to cycle the key a few times before starting, and see if it cranks a long time then. If it starts normally, it will be fuel bleed down for sure.
Quote from: chrome;382185
try to cycle the key a few times before starting, and see if it cranks a long time then. If it starts normally, it will be fuel bleed down for sure.
x2
CoogarXR : 1985 Cougar XR-7
This explanation makes sense to me and seems to fit with the symptoms, but  I did try turning the key off and on several times before starting today and it didn't seem to take off any quicker.
