Topic: Rim size and backspacing (Read 1315 times) previous topic - next topic
I will have a stock width rear end, tube k member with 95 spindles so I should be close to stock width in the front. I have been reading and it seems I can go with a 10" rim in the rear with 5.5 back spacing. Does that sound right? What size drag radial could I fit also? The front rim will be narrow 4"? What backspace would I need for the front? Thanks in advance.
1988 Thunderbird LX  557/C6 project. UPR tube K-member, A-Arms, Strange 10 way adjustable coilovers. SN-95 spindle,brakes. Manual rack, bump steer kit.  MM castor/camber plates, Dynatech 2 1/8 swap headers. Quick 9" 35 spline Moser axles,CHE lower c arms,
