Topic: Water pump pulley (Read 1005 times) previous topic - next topic
Water pump pulley
Anyone have one they dont need? the on I saves isnt for a ford... which is really disappointing..
Oh and the 4 bolts that hold it to waterpump.
Water pump pulley
I have one I got a while back that did not fit what I needed it for. I will take a look for it get a pic and the part number off it.. Give me a few...
:ford::oldcougar::mercury:
Water pump pulley
Here it is... I bought it because I was missing one for my 3.8 and this one did not line up right..
A little dirty, I do not have the bolts though..
Water pump pulley
Thats my trouble. the motor and all the parts are from a 86 f150. the 5.0 underdrive kit my buddy gave me wont bolt up right.
Imma thinkin Ive got a junkyard run comming up
Water pump pulley
It wouldn't bolt up to my 3.8 but don't know of it'll fit a 5.0. I didn't try and look up the part number to see what it's from.
Water pump pulley
I have one from the original 88 5.0. I just hope your not in a hurry, Im offs till around march 9th. You can have it.
1988 Thunderbird LX  557/C6 project. UPR tube K-member, A-Arms, Strange 10 way adjustable coilovers. SN-95 spindle,brakes. Manual rack, bump steer kit.  MM castor/camber plates, Dynatech 2 1/8 swap headers. Quick 9" 35 spline Moser axles,CHE lower c arms,
Water pump pulley
the pulley pictured above is the same from a 89 mustang 5.0 so it should work
as for the bolts you can pick them up at any parts/hardware store. I'm not sure, but I think the threads are M8x1.25 like most of the threads on the engine.
Water pump pulley
I figured it was from a 5.0
