Topic: Will this 4 eyed hood fit my 88? (Read 3010 times) previous topic - next topic
Someone told me it would, but wanna hear from the experts here. This is the hood.
1988 Thunderbird LX  557/C6 project. UPR tube K-member, A-Arms, Strange 10 way adjustable coilovers. SN-95 spindle,brakes. Manual rack, bump steer kit.  MM castor/camber plates, Dynatech 2 1/8 swap headers. Quick 9" 35 spline Moser axles,CHE lower c arms,
Yes.
...and there was light!
Thanks!
all 83-88 hoods are the same, with the exception of 87-88 TC hoods, only because of the scoops.. but the scoops have nothing to do with fitment
Quote from: V10KLZZ71S;381470
Thanks!
Your welcome!
Quote from: Shadow;381474
drivers side scoop will hit the top of the compressor bracket if used...
must be ground down or removed for clearance.
Quote from: daminc;381483
what's a/c? lol should have clarified a little.. doesn't mean anything for the hood (itself) fitting
Well, if you've got water pouring directly onto the engine when it rains, then it doesn't quite fit all the way, does it? ;)
And 1983 hoods are different.
Quote from: EricCoolCats;381511
you serious?! how so?
It is a very nice carbon fiber hood.
This is the first time I have read that anywhere, granted I know very little about the pre '86 cars. Learn something new everyday! :D
It's just the mounting holes to the hinges...but it is different (as well as the hinges themselves). 1984-88 are pretty much all the same hoods.
IT.. i grabbed a hood for MY83T's heritage, off an 87 cougar..
Quote from: Shadow;381577
As long as you got the hinges too, you're fine. Where they bolt to the car is the same, just where the hood meets the hinge is different. If you swap hoods hinges and all, you won't see the difference.
CoogarXR : 1985 Cougar XR-7
are the hinges visibly different, or are they they same with the exception of the hood mounting holes? if they're visibly different, than i need to sell the hood and find an 83 specific hood
