Topic: ler (Read 7990 times) previous topic - next topic
ler
Reply #45
Quote from: TOM Renzo;381597
Sounds good I will bow out. Just thought you would like to know the facts. Sorry for clouding the conversation with facts i should have known better. Thanks
Your info HAS been discussed here before.
http://www.foxtbirdcougarforums.com/showthread.php?19019-ler-flow-tests-and-Exhaust-theory
Just sayin'
My first cat was an '87 3.8.
I kept the stock manifolds, put dual 2.25" pipes on it with catalytic converters and Thrush turbo pack lers.  I know plenty of guys that have put duals on 3.8 litre Mustangs and IMO the setup on my old 3.8 sounded WAY better than all of them.  In no way did this car sound like an import.  Deep basso rumble at idle and part throttle.  It started to get the hint of the sound of a radial engine at full tilt.  It was LOUD though.  It rivaled Ford 4.6's with SLP Loudmouths as far as sheer volume.  Car alarms were set off on a regular basis.
