Topic: Brake Problems (Read 1193 times) previous topic - next topic
Brake Problems
Help  OK I need some help.  I have just had a complete break work over....New Front calibers, Roters and both break lines on the front replaced.  The same with the rear.  Then I found I had a leak in the upper ABS system/.  It seems there is a crack or something that is letting the fluid run right out.  The leak is located at the break pressure senor that is attached to the combo break valve.  I have a 1988 Turbo coupe and have not been able to  locate a part for it.  Do any of you have a spare pressure sensor or the whole system.  I am also hoping that I will be able to remove the break line as it is heavy rusted.
Thanks again for the help
Brake Problems
Salvage yard only as far as I know if you are referring to the combination valve mounted to the inner apr0n under the master cylinder.
Darren
