Topic: This should work just fine (Read 1423 times) previous topic - next topic
I have my frt suspension parts on its way, so I turn my attention to the rear end. In the next month or so, gonna pull the trigger on this. I will have to weld the control arm brackets on. I dont think I will ever break this piece. Uses Explorer brakes and e-brake.
1988 Thunderbird LX  557/C6 project. UPR tube K-member, A-Arms, Strange 10 way adjustable coilovers. SN-95 spindle,brakes. Manual rack, bump steer kit.  MM castor/camber plates, Dynatech 2 1/8 swap headers. Quick 9" 35 spline Moser axles,CHE lower c arms,
If you going through the trouble why not four link it?
I am gonna do a coilover conversion and use aftermarket control arms. I wanna back half my car bad, but for now I will run with the control arms in stock locations. Mini tub is an option Im thinking about also.
Any particular reason you are looking at this versus an 8.8 rear?
Darren
