Topic: What is this? (Read 2255 times) previous topic - next topic
What is this?
What does this do? When i rewired a tc cluster to my v6 it started to get super hot, but only while the headlight where on.
What is this?
It goes on the back of the instrument cluster, I don't know what it's called though.
...and there was light!
What is this?
xx
What is this?
Yeah i took it off the back because it was burning hot.
What is this?
What is this?
Yes i know where it goes... but do i need it?
What is this?
I believe it's the ivr, it lowers the voltage feeding your gauges and is pr0ne to failure. Somewhere there's a thread on how to make a better one.
What is this?
/\Thanks, Didnt know what it was either besides some kind of weird fuse or jumper.
I could see rust as a potential problem with it, Try cleaning the contacts and such maybe.
What is this?
^ what I thought, is it necessary?, because gauges seem to work fine without it.
What is this?
it is a resistor for the cluster illumination.
it allows you to dim the light down low.
i took mine out when i put in LED's.
if you keep your cluster fully light with out dimming you dont need it. but if you turn it down it helps making them dim.
thats the reason it got hot.
Brian J Larkin
1988 Tbird Turbo Coupe
1989 Cougar XR7
1995  Ranger Splash
