Topic: Early morning starting issue with the Sport.... (Read 8508 times) previous topic - next topic
In the morning, when I go to start the Sport, for the last 3 days, it just turns over ....over and over, but won't start, then, after a few minutes, it finally does start, and runs rough. Once I drive it for a few minutes, it does fine, and starts fine for the rest of the day. I pulled the fuel pump and changed the strainer, the pump seems fine, especially since once I drive the car for a bit, all the power is there. Swapped the TPS, no change...all the plug wires are good, the distributor hasn't moved. The idle seems fine.....once I get past the rough running condition. Any ideas. I haven't run codes yet, but will tomorrow.
I would run codes first. Chesk your ground by the battery under the starter solinoid. Maybe the ect sensor.
temp sensor?.....
I'll check the ground. It would seem if it's bad it would give me issues all the time, not just upon early morning starting.
if the sensor is out of range like  mine have gone... it's hard to start when it's cold, until it warms up.  I've gone through 3 or 4 in my cougar
ECT? Water temp sensor on the front driver side of the intake?
I'll grab one in the morning.
that's the one... You can test it on a meter to see if it's out of range
Wait, I AM thinking about the right sensor aren't I? (been a little distracted lately).
yep, you can test it with a meter to see if it's out of range... the code will come up too for being out of range if it's the problem
I loaned my tester. I'll just go get one. If it doesn't fix it, then I have a new sensor anyway.LOL. Give me 15 minutes......I'll be right back.
lol... ok
Sorry for the delay. As soon as I left here yesterday, I ran down and got the new sensor. I'll know if it helped in about half an hour, then I'll report back.
BAM !!!! Started right up. That just may have been the cure. Thanks a lot for the input.
Run codes to see if its in your stored memory. Pick up a cheepie $1.99 volt meter at harbor freight next time your there, and loan that one out.
And the ect stands for engine coolant temp sensor.
